Toshiba C850 won't charge when plugged by an AC adapter.
My Toshiba Satellite C850, wont charge, when I plugged the AC adapter it says 100% full charge, and when I unplugged it, it says 15% remaining and the AC won't lit. PLEASEEE!!! HELP!!!
Hi,
99% this is a Battery problem. Of course, try first with another charger.
Regards.
このアンサーは役に立ちましたか?
Check battery health, could be signs of an old battery not holding a charge properly.
If the battery is not end of life then you should look at the power adapter and the first two mosfets.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 1,359
