メインコンテンツにスキップ
4インチディスプレイ/カラーバリエーションは様々あり/3種のモデル/16, 32もしくは64 GB容量
331回答 すべてを表示
iPod 5 (16GB, no camera) won't turn on at all!
My cousin was using my ipod and she said it won't turn on. She then told me that she took it to the cellphone store on the corner and the guy said the jailbreak was messed or something. I told her to bring it back because im not paying 50$ if that's the problem. I brought it backed and tried to put it into DFU mode but it just won't turn on at all. It's very important that i get the memory from it because i have photos that I must have for my job. Would i be able t open it and take the memory out,w aht do u suggest?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
3件の回答
Try leaving the iPod plugged in for a few hours, if you are still having problems try doing a soft reset. You will not be about able to take the memory off the logic board because it is solder on the board.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have problem with my iPod Touch 5th Generation too.
Yesterday it run out of battery and while charging I tried to turn it on but it couldn't startup.
When I push the lock buttom it appear the apple sticker but then it desappear and nothing else happens...
Could somebody help me with that, please?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
i had the same poblem just ty this
Follow this instructions:
1 - Simultaneously press the top button + home (central) button.
2 - Keep both buttons until the Apple appears.
3 - Then release only the top button but still hold the home button pressed.
4 - The iPod goes into recovery mode and then you can restore it via iTunes
i hope this helped.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I already did that too. but still no apple logo appeared and still on a black screen. I've already did the restore iPod, still nothing shows. is there any other possible thing to do in order for my iPod to be back to normal with clear display?
さんによる
コメントを追加
回答を追加する
deshawn さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 3
今までの合計 5,304
