メインコンテンツにスキップ
iPad 2 has poor signal after a few wireless antenna replacements.
I originally replaced the digitizer and antenna, started experiencing issues with poor signal. I assumed that the wireless could've been defective. So, I decided to purchase four wireless antennas. None of them work, same problem. I've did so much research and have had no luck. It's detected the 5Ghz network first, then the 2.4Ghz (When next to the router). I'll connect to it, and I'll see it drop from three bars to two, and maintain the two. I'll began walking away from the router, and problem worsens. I've tried restoring factory settings, and resetting network settings. No luck. I'm in desperate need for some assistance. Thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
選択されたソリューション
This is still probably and antenna issue---if your four new antennae came from the same batch, they are the same as one.
The WiFi chipset on the board is easy to replace, it is a plug-into-a-socket chipset. Take a look at the board to see the small component that the WiFi antenna plugs into. Damage to the antenna socket could be a possibility here.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Jerry Mosley さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,378
