メインコンテンツにスキップ
PlayStation VitaはPSPの後継機種です。 強化されたプロセッサとグラフィックスに加えて第2のアナログスティックが追加されました。 2011年12月17日発売
160回答 すべてを表示
Ps Vita, Battery solder
I was replacing a analog stick on my ps vita. When I tried to remove the battery the clip that connects to the motherboard, it came completely off. Is there a way I can solder the battery wires directly to the motherboard. if anyone can help I would appreciate it. Please Help.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
12 件のコメント
Hello I did the same mistake, i wanned to unplug the battery and replug it (i had battery issues) and i broke the solder (actually the black plastic part at the top that hold the wire) so now i can't connect the battery to the motherboard anymore.
Here is a picture of the black plastic i broke :
http://i.imgur.com/YOiIPhQ.jpg
さんによる
somebody help please
さんによる
Mike, I had the same problem. Or at least a similar one. I was separating the two halves to replace the battery and the entire white plastic cradle part that attaches to the motherboard just came off the circuit board. It came apart effortlessly! It was as if it was barely attached to begin with. Poor quality circuitry!
I'm hoping for an answer here as well. I'm willing to solder if that fixes the issue.
さんによる
Have you got a photo so we can see the extent of the damage ? If your in the uk i have a couple of boards knocking around
さんによる
7件以上のコメントを表示
コメントを追加
1 件の回答
ベストアンサー
Hi, this might come too late but, just below where the battery connecto once stood, there are three solder points correnponding to each of the battery terminals, just solder the battery directly there...
このアンサーは役に立ちましたか?
スコア 2
5 件のコメント:
Hi Estuardo @taquito77,
Thank you very very much! I now have a working vita!
For the others that possible will view this post the 3 solders joints are straight forward the conector scheme.
さんによる
I have the same problem on my slim vita, does anyone know of any alterntive solder points for the battery on the motherboard? thanks graham
さんによる
hey i wanted to take my batter connecter out and the whole white thing came off then when i tried to take the white part off the black my white part snapped in half is there any way to fix it
さんによる
Hey. I encountered the same issue. The white connector attached to motherboard broke. Can i just solder directly unto the three nodes?
さんによる
@Tan neil Yes!!! here is a video that may help you! https://youtu.be/PtHYKgwCtAY just solde the each pin to the corresponding solder point below.
さんによる
コメントを追加
回答を追加する
Mike さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 13
今までの合計 3,347
