Where is this part located?
So, I try to put my ps3 back together but I can't seem to figure out where these parts are located? (pic below)
この質問は役に立ちましたか?
この質問は役に立ちましたか?
These are two separate pieces. The smaller one goes along the front edge of the console on the bottom casing, under the disc drive, under the motherboard. Flip it around until you see how it aligns on the casing.
The larger piece goes along the right edge, on the bottom casing under the motherboard. It attaches on the right side about 2 inches from the front leading edge and rests on the bottom of the casing.
このアンサーは役に立ちましたか?
Are you sure this is a part for this particular model? That looks like just a faceplate shield which would probably attach to the top of the metal plate over the motherboard. Other than that I'm not sure.
このアンサーは役に立ちましたか?
Yes they are for this model
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 136
