What is work of U18_RF in iPhone 4s?
I want to know that what is work of Baseband Power Diode U18_RF in iphone 4s?
Take it off with some flux and an iron. U18_RF is some sort of baseband logic gate. If it is gone, the phone will always be searching, it is one of the common 4S battery pry damage faults that will result in a phone always searching and not producing an IMEI.
You need to replace it.
Try to avoid using hot air on tiny phone boards if possible. The likelihood of doing more harm than good is too high. It is not necessary to use any hot air to remove and replace this component.
jessa
このアンサーは役に立ちましたか?
Thanks for very useful response.
How do i confirm about this ic is this working or bad.
My iphone not searching. . but No service problem.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,669
6 件のコメント
Jay, you want to know how to replace the IC?
oldturkey03 さんによる
No but I also want to know replacing idea.When I heat the ic upper part broke and internal material still jointed with pcb.How could I completely remove ic from pcb.and please also provide main work of this ic in iphone 4s.
One thing more: From where can I buy U3_RF for 4s?
Jay さんによる
Hang on, you tried to reflow and overheated the IC? It melted on the board? Post images of this with your question. That way we can see what you see
oldturkey03 さんによる
Oh I can understand about image but not possible now ,because i'm out of town.I think ic not properly melting,any liquid or paste required for easily removing?
Jay さんによる
Jay, have you done a reball before?
oldturkey03 さんによる
1以上のコメントを表示
