IP address is not taken by router - NETGEAR DG834pn
the router is not able to have an ip address ????
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Are you trying to setup a static address so you can connect from the internet into your router (to access your home computer while your on the road). If so you'll need to talk with your ISP for a static IP address assignment then you can program the Router (review your owners manual).
Don't forget to also just reseting your router by unplugging it from power wait 1 good minute and restart. Otherwise you'll need to talk with your ISP support people as they may have an issue with the cable line or your settings they control.
このアンサーは役に立ちましたか?
I have the same issue, so please help me.
このアンサーは役に立ちましたか?
You'll need to give us some details: Have you spoken to your ISP? Have your tried resetting your Router? Are you using DHCP or do you have a static address assignment from the ISP?
I had the same issue, can anyone help me?
Sure we can help, but you'll need to help us help you! Again: You'll need to give us some details: Have you spoken to your ISP? Have your tried resetting your Router? Are you using DHCP or do you have a static address assignment from the ISP?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 249
1件のコメント
Can you explain what you mean here. Most Routers use DHCP from the upstream router.
Dan さんによる
