lines on the screen
my iphone 5s fell of my lap nd fell on the ground and got ah few lines to the left side of the phone.... and the left side touch not working only the right
lcd connectors might have came loose, reconnect them, it's most likely that if not then you will need an lcd replacement
このアンサーは役に立ちましたか?
bcuz i change my screen last week proberly the jacks loose
Yip this can happen if the digitizer cable come loose disconnect and reconnect if the screen still has lines the unfortunately it's a damaged screen
このアンサーは役に立ちましたか?
i need to buy ah new screen
Yea if you do what I sayed and screen is still bad then yes you will need a new screen
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 97
