メインコンテンツにスキップ
Xbox 360は、2005年11月22日に発売されたMicrosoft製第二世代ゲームコンソールです。
428回答 すべてを表示
How do I fix xbox 360 green circle but doesn't work?
I have a X Box 360 console that the circle light goes around blinking as usual but then turns solid and nothing is on the TV. The disc tray will not open either. I have unplugged it and left it unplugged for 24 hours and vacuumed the dust out as much as I can without taking it apart. I can hear the fan going but that is it. Does anyone know how I can fix this problem. I called Customer Service and they said it is something internal. Any help would be greatly appreciated.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
5 件のコメント
oldturkey03: I bought a new AV cable for the XBox 360 but it still did not work. I decided to try my DVD player in the same outlet on the TV and it didn't work so I think it may be the connection on the TV itself. Thank you so much for all your help.
さんによる
My xbox 360 turn on but the green light on the system doesn't but the power supply work do any one know how to fix it
さんによる
&&^& You @%^$$@$ you ruined my xbox 360 slim
GOT THE RED LIGHT OF DEAD
さんによる
well, my xbox 360 e just have the green light with out the ring light, and the controllers just blinking... the console not turning on.
さんによる
If it shows a red light just slap on top of the console and unplug it each time it does it till it works
さんによる
コメントを追加
4件の回答
ベストアンサー
Floria,four flashing lights indicates that the console does not detect an audio/video (AV) cable. Make sure that the AV cable is correctly connected to the Xbox 360 console. Disconnect the AV cable from the Xbox 360 console, and then reconnect the AV cable to the Xbox 360 console, from here I know you already tried all that but do wanted to add it for completion sake.
If the 4 red lights continue to flash, try wiping the metal area of the AV pack with a dry cloth. The metal area is the end that plugs into the console. Wipe the metal area thoroughly, and then try the AV Pack again. If the AV cable is correctly connected but the four red lights are still flashing, substitute a different AV cable if you have one available.
Flush the cache memory by following the steps below:
-Shutdown your Xbox 360 console
-Press and hold the SYNC button first, then press the POWER button together.
-When your console reboots, let go of the POWER button BUT keep on pressing the SYNC button
-When your console has completed rebooting, all cache memory will be flushed.
from here. But, that is a pay site and all the information is available in the public domain.
Check on here for further information and how to determine secondary error codes and see what you come up with. It is my gut feeling that you do have an overheating problem (but try the easy stuff first) If your error is caused by overheating, the kit should fix it. Of course make sure that your Xbox is not covered by warranty or anything like that. You would not want to void it. Also make sure that you clean it well of any dust and obstruction and that you provide good air circulation to prevent any overheating issues. Of course it is also possible (less likely) that you have a variant of the RROD, which would need a different approach. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 3
5 件のコメント:
oldturkey03 : The console green light in the middle comes on first. Then the green lights go around the circle. then the green light turns solid for about 2 seconds. Then the green light in the middle is all that is on. None of them are red or blinking. I tried the disconnecting from the console and tv, Then reconnected after I wiped it with a clean cloth but it still is not showing up on my tv. I also tried the SYNC button suggestion but that didn't work either. I can hear the fan running in the back but that is all. Oh and the rectangle thing that connects the console to the electrical cord is yellow before I push the power button and then turns green.
Don't know if any of this helps you help me but I thought I would let you know. Thanks for any help you can give.
さんによる
thannk you its work
さんによる
My xbox turn on but my green light doesn't on my console
さんによる
i have and old xbox 360 and the console will turn on but the light wont come on
さんによる
@Alex Hunt so what does it do? This " will turn on but the light wont come on" is not enough information. The more information you provide the greater your chance in finding out what's wrong with your xbox
さんによる
コメントを追加
This worked for me.
Ensure no remotes (wired or wireless are attached). Press sync key . While its pushed turn the power on but do not let go off the sync key. It may take few seconds to couple of minutes for the system cache to be deleted. The unit will power-on fine after that.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Mine is doing the same thing. All 4 green lights are on and stay on. They don't turn red and the only thing that doesn't work is when I try to play a disc I've put in. It makes a snowy picture come up on tv screen, then turns black.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I turn on my console, power supply light is green,controllers are on, but power button on console is off. What do i do?
さんによる
コメントを追加
Hello,my problem is that the green circle light it doesn't come on and my controller can't connect but my console it come on
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Same problem
さんによる
コメントを追加
回答を追加する
Floria さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 7
過去 30 日: 42
今までの合計 24,088
