メインコンテンツにスキップ
モデル番号A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5もしくは 3.4 GHz Core i7 Processor, ID iMac12,2
708回答 すべてを表示
Won't start up. Only hear fan for a sec.
I have a 27 inch iMac EMC 2429 that began to freeze and I would get an error message on the screen that I need to restart my computer. So I would hold power button until it shut off and then I would restart my computer. It would work fine for a while then it would need a restart again. This happened over a period of two or three days. Then on the last restart my iMac would power on and I could hear the fan start for about a second and then shut off. As long as I leave it plugged in the iMac continues to try to restart over and over again but the only thing that would happen is the fan kicks on for one second and then shut off with no video or chime. I opened it up and get only LED light 1 turns on then the second light turns on with the fan but turns off when the fan shuts off. Lights 3 and 4 never come on. Is it the power supply or am I missing something? Is there anything else it could be? I need my Mac back! Thanks in advance for any help.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
I have the same problem. I even replaced the power supply, but it didn't help.
さんによる
コメントを追加
2件の回答
最も参考になった回答
The #1 LED indicates trickle power and you'll get it even with a bad power supply. There are a couple of recalls on the machine so knowing your serial number would help.
See what happens if you try starting with the "R" key held down.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Same result.
さんによる
コメントを追加
If it was the power supply, you wouldn't get any power at all. From what you're describing it sounds to me like a bad logic board. There was likely a flaky component that was causing your initial Kernel Panics that continued to degrade as time went on.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Angela さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 324
