メインコンテンツにスキップ
A touchscreen smartphone made by LG released in September 2013 with the model number VS980.
185回答 すべてを表示
Only speakerphone works during calls, can't use normal phone mic
When I make/take a call, I can only use speakerphone to communicate. If I use the normal mic (as in holding it like a normal phone) then nobody can hear me. I believe I damaged the noise-cancelling mic when I dropped it, the one at the bottom of the phone which is used for phone calls.
LG G2 VS980
What piece would be needed to fix this issue?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 29
23 件のコメント
I have this issue as well but mine also has static
さんによる
My phone only let me talk two people on speaker when i dial out i can not hear anything until i put it on speaker phone also same thing with talking on it
さんによる
I have same issue.when I place call the mic and speaker dio not work. Caller can hear me but I cannot hear them. in the old land line service we called it one-way communication.
さんによる
Try turning your phone over and pressing the area just under the camera on the back.
さんによる
I have also the same issue. Whenever i make a call other linr cannot hear me but i can hear them.
さんによる
18件以上のコメントを表示
コメントを追加
13件の回答
ベストアンサー
jon, you will have to disassemble it. Check to make sure that it is still properly connected on CN304 and that the mic rubber is properly aligned and does not obstruct the mic. After that, you may have to consider replacing the mic. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 9
2 件のコメント:
Thank you! This was very helpful. The teardown doesn't specify what would need to be looked at/replaced, so this clears things up. Thanks again!
さんによる
where can l get it fixed cheeply
さんによる
コメントを追加
最も参考になった回答
Hey, i know I'm super late but for anyone else having this problem, simply press your thumb gently near the top by the camera then try it.
このアンサーは役に立ちましたか?
スコア 22
29 件のコメント:
The phone doesn't work unless you plug in handsfree or switch on speaker. I tried software changes, cleaning the holes with pin, remove battery. Nothing works. But this trick : "press your thumb gently near the top by the camera then try it" it's work for me. Thanks a lot
さんによる
Crushed Ice has the perfect solution! Thanks a million! I could not believe how perfectly and easily this worked. God bless you, Crushed Ice.
さんによる
What? Your kidding right? My camera icon is bottom center.
さんによる
WOW! Went to bed with this annoying problem last night and wanted to take the phone to the service centre this morning. Thought might as well google it.. and I saw this. WORKED! MAGIC! I cant thank you enough!'Bless you Crushed ice.. People like you are truly God sent.
さんによる
OMG! This worked perfectly!
さんによる
24件以上のコメントを表示
コメントを追加
a very simple selution- clean the bottom left holes near the headphone jeck with a pin. worked for me.
このアンサーは役に立ちましたか?
スコア 4
4 件のコメント:
thanks man.this is the answer i was looking for.there were dust in holes.thanks again :D
さんによる
Wow... I was gonna have to buy a phone before I read this fix... It silved my prob. Thanks
さんによる
such a simple solution yet it never crossed my mind
さんによる
Thanks tryed it and now my phone works so far so good thanks
さんによる
コメントを追加
Hello i kept reading and searching and this one post said to press your phone around the camera area ...really it said top. But i pressed top sides and bottom and it worked .. Wooowwww
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
It solved my problem. Thanks for saving me some $$
さんによる
コメントを追加
My girl had the same problem. We checked everything in settings and all. Tried turning it off, tried resetting it. And nothing.... Maaaan, after all that, she thinks of taking the battery out and putting it back in.. Just like that. I could hear her and she could hear me..
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Push lightly on the back camera. Apply a little pressure. Worked for me. I could now hear calls the normal way.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
What does the camera have to do with volume, sound, speakerphone, calls..? Regular phone on my Tracfhone Alcatel hear “Nothing…..” With “Speakerphone” Awful..barely hear other party.Attempting to schedule a Dentist appt. “Excuse Me” Please repeat that? What was that? What time did you say Sorry can’t hear you… This is so “Awful”..
What I do not understand when I had my Alcatel Flip Phone. I could hear everyone loud and clear. So nice… So I decide to go with a Android, and it’s the worse ever.
When I’m on a call, and I get a text message same time, it disconnects me from the caller.. I do not understand this.. Why? Then I have to start over,,, an apologize..
さんによる
Alcatel flip phone ?? I would say that's your problem
さんによる
コメントを追加
I had the same problem and I cleaned out the little hole and now I can respond and people can hear me.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Turn your voice enhancement on but u can't have speaker on or Bluetooth... Then look for privacy setting and uncheck the box if it's checked or vice versa.... That helped mine,,, but then I also downloaded from play store free "VOLUME BOOSTER" and just let the phone do automatic setting now it works great with music videos and calls.... Highly recommend this app 100%
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
But I didn't drop mine
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Is there an app that can cause an LG 20 PLUS PHONE to only allow people to hear me when I use speakerphone but not hear me talking through the regular phone
さんによる
My lg tribute has been acting up for weeks now, there is a wierd list that runs down the entire right side of my phone in little white letters how can i do to get rid of this
さんによる
コメントを追加
Why do I have to put the speaker on to hear my calls. If I don't they can't hear me and I can't hear them unless it's on speaker
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Can someone spy on my phone using a code which is connected to Ford truck
さんによる
コメントを追加
Maybe a new phone will settle it for me.. I dont like spy for dual mic for third party app. Im not rich. I use Meizu U20. I Convert to Google user end version latest android 6 for Meizu release Chinese version. Hate after that my mic doesn't work, must use speaker phone. Please some one helping me.. Qaindahu26@gmail.com my email for solution. Thanks.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Clean out the mic hole on the bottom left of the red magic three. It's done this to me twice !!! Works every time ;)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I thought that the pressing the back of the phone made it work. Whereas it was just taking it out of its case that made it work. Back in the case I have the same problem.
Out of the case I still can't hear people if I put it on speaker phone.
Is it the end of the phone or is it repairable ?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
jon さん、ありがとうございました!
統計データ:
過去 24時間: 18
過去 7 日: 149
過去 30 日: 608
今までの合計 252,264
