メインコンテンツにスキップ
2013年10月に発売された7インチAmazonのハイエンドタブレットモデルです。モデル番号はC9R6QMです。
55回答 すべてを表示
How do I open my Kindle fire HDX case to replace screen
My screen is cracked on my Kindle Fire 7" HDX and I'd like to replace it, but i'm having trouble even getting the case open. There also don't seem to be any guides on how to do this with an HDX.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 22
コメントを追加
4件の回答
最も参考になった回答
Hi Alison,
Watch the start of the teardown video as a reference. There is a strip of plastic on the back that needs to be removed as a first step. It is shiny and has holes in for the speakers. It is held in place by tabs on the ends and adhesive especially off from the center of the strip. Use a safe open pry tool, isesamo, or a spudger to release the tabs and start peeling the plastic strip away from the kindle body.
このアンサーは役に立ちましたか?
スコア 6
コメントを追加
Just finished a screen replacement guide for the HDX. Check it out!
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Thanks! I will check it out! Thanks for your earlier message also, I haven't been able to try anything yet, but hopefully tomorrow!
さんによる
コメントを追加
A flat head screw driver will work just put it on the end of the back and pry open on each side
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
use something plastic like a spuger a credit card or guitar picks that way you wont damage the case or screen
さんによる
コメントを追加
On the Kindle one on the Kindle to need to take off the screen to replace the battery. How do I do this. There is no way to take the back off. This Kindle is all one piece.
Thank you
Tony
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I thought mine was all one piece, too, but it isn't. There is a little black area at the top of the kindle and that is the part that needs to be loosened so the back can come off. I was suppose to get the tool with the replacement battery, but it was not included so I am going to try one of the suggestions above. Even watching the videos, it shows how difficult it is to remove and how much it is all sealed together. I found a couple videos I'm going to watch: https://www.youtube.com/watch?v=g6e5-H_U... and
https://www.youtube.com/watch?v=iHT10Mhp...
さんによる
コメントを追加
回答を追加する
Alison さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 7,605
