After changing power button flex cable the sound of my voice is muting
After changing flex cable the sound of my voice over cellular is muting during calls. FaceTime audio works fine. I think something with upper mic or broken flex cable?
There is a mic on the cable, which is use by the noise cancellation feature.
If this mic is not working properly, erratic noise cancellation may distort your voice call.
このアンサーは役に立ちましたか?
Where exactly it placed? Do you have a pic?
Changed what flex cable?
The mic for calls is located on the charging port at the bottom.
the top mic is used for FaceTime and recording front facing camera
このアンサーは役に立ちましたか?
sound buttons and power button flex cable. And exactly after it's changing this problem appears.
Yes the upper mic is located on the power volume flex but when talking normally on a call that mic shouldn't be used
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 68
