iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
tamsin @tamsin22030
評価: 1
投稿日: 2014年9月3日
i can get notifications and see things on my screen but the touch is unresponsive. what can i do/try?
この質問は役に立ちましたか?
con @con82159
評価: 37.6千
IRepair iphones
22
51
42
Hard restart hold power and home button together at same time for 7 seconds then let go of home and keep pressing power..
What happened it to make it unresponsive more info needed
このアンサーは役に立ちましたか?
PhoneAsylum @phoneasylum
評価: 2千
5
2
You may just need to restore the iPhone using iTunes if this doesn't work it's most probably your digitizer (the thing that controls the touch). The flex may be disconnected or you may just need a new screen. Use this guide for help.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 77
