メインコンテンツにスキップ
2012年6月発売。Core i7プロセッサ 、Turbo Boost / 最大1 GB DDR5 Video RAM
597回答 すべてを表示
Swap display between 2011 & 2012 MacBook Pro?
Hi there!
Basically what I want to do is to take a high-res glossy(!) display from a primo 2011 Macbook Pro and use it as a replacement for the standard res screen on a mid 2012 Macbook Pro. Is this possible?
From what i've read its seems possible I'm not sure if the connectors will match.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
100% works, "but". Typing this on a 2012 MacBook Pro unibody 15 with a 2011 Unibody 15" high res matt display and top case.
The keyboard failed on mine, so I swapped the display and top case (and went for the upgrade along the way as a toasted 2011 model wasn't much more than a top case).
The "but" is that the connector is slightly different. The wiring is identical, but you have to bend (not break!) the tabs at either side of the connector on the logic board, which is a delicate job. The connector then slots in and locks into place as expected.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Parts catalog says won't work.
11's fit only '11s - 12's fit only 12's.
If this answer is acceptable please remember to return and mark it.
MacBook Pro 15" Unibody (Early 2011-Late 2011) Display Assemblyの画像
製品
$149.99
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I know it says that in part-list in here but I have read about others who've done this successfully.
さんによる
I'm confused. You already knew the answer but asked a question about it anyway? Then you should ollow the direction of the others.
さんによる
コメントを追加
回答を追加する
Thomasgd さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 6
今までの合計 891
