メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2014年7月28日に発売されたSamsung Galaxy S5 miniは、800万画素のリアカメラ、720pディスプレイ、指紋センサー、耐水性を備えた携帯電話です。兄弟機であるGalaxy S5と比較して、ディスプレイの大型化、バッテリー駆動時間の延長、カメラのアップデートが行われています。
Battery change, increased life
Is it possible to replace the original battery with one with a larger capacity
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
3件の回答
Hey Chris,
If you see a battery that has a higher mAh then the original Samsung battery, then you should make sure that it is reliable.
Here are some trustworthy sources:
-ZeroLemon
-Seido
-Mugen
-Pacific Power
-Anker
-Batteries + Bulbs
-Spark Fun
-Hope this helped
-Be careful when shopping, I know that I've said that they might be potentially harmful but I said that through my experiences. I've bought three from amazon and one from eBay and they were not reliable. Make sure that you look at the reviews of the product if you are purchasing them.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Why would a battery with a higher mAh be potentially be harmful? Can you explain this?
さんによる
コメントを追加
最も参考になった回答
Chris Ford, yes you absolutely can. There are no harmful consequences by using a battery with a higher mAh rating. As long as it fits properly and has the proper connectors. mAh is nothing more than a description of the total amount of energy a battery can store at one time. Since it will last longer, it will also take longer to be charged back to capacity. No other issues with it. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
There's nothing wrong with using a 3rd party battery, for years I have used an Anker 4400mAh battery for my Samsung Galaxy S3. I can't fault it whatsoever, it's been absolutely fantastic and to this day still holds charge well. I would recommend Anker, they're not the most expensive either but have always been reliable for me.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Chris Ford さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 27
今までの合計 1,763
