メインコンテンツにスキップ
2010年4月発売。2.4, 2.53 GHz Core i5 or 2.66, 2.8 GHz Core i7プロセッサ
579回答 すべてを表示
Disassembling the Anti-Glare Screen
If anyone is familiar with iColours, they sell colored inserts that go behind the apple logo on the lid. In order to install these, it is necessary to take apart the entire display housing. With the glossy model, the instructions are to use a suction cup/heat gun/credit card and take off the glass, after which it is very straightforward. However, the anti-glare model obviously is a little different. The only thing covering the LCD itself is the bezel/black trim. Does anyone know how to disassemble the AG model display?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
選択されたソリューション
Guide Published!
I finally published a guide on replacing the Matte finish LCD. You can find it here: MacBook Pro 15" Unibody Mid 2010 Matte Finish LCD Replacement
Update
I just went ahead and tried to remove the Matte LCD screen and was successful.
The key is to remove the bezel, which is attached to the assembly using doublesided tape, similar but not exactly as with the glossy screen. Underneath the bezel, the screen is screwed in just like the glossy LCD assemble. As with the glossy, a heatgun works for this purpose. One big difference from the glossy (aside from the bezel) is that there is NO coverglass. The matte glass you see is optically bonded to the display, which is screwed in underneath the bezel, and so using suction cups will not work.
It helped me tremendously by removing the rubber seal around the bezel first. Steps were:
1. Remove the display assembly as described in steps 1-20 of the glossy tutorial MacBook Pro 15インチ Unibody Mid 2010 LCDの交換 .
2. Applied heat around the edge to losen the tape.
3. Remove rubber seal on lower corner. Using the sharp end of the spudger helps.
4. Apply more heat
5. Wedge flat end of spudger between bezel and screen to remove, while applying heat gun.
6. Remove the LCD as in steps 31-36 of the glossy tutorial MacBook Pro 15インチ Unibody Mid 2010 LCDの交換 .
I still haven't put this back together, but it all came apart rather cleanly. I'll post how this goes back together once I get the replacement LCD.
Murdercity - Were you able to remove the bezel?
MacBook Pro 15" Unibody Mid 2010 LCDの画像
ガイド
難易度:
とても難しい
3 hours
MacBook Pro 15" Unibody Mid 2010 Matte Finish LCDの画像
ガイド
難易度:
難しい
3 hours
このアンサーは役に立ちましたか?
スコア 3
コメント:
+ Thank you for bring this back here. This does clear up the differences between the 2. Keep your double sided tape well protected. You will be using it again when the new lcd arrives.
さんによる
Actually, the double sided tape was gone, but ordering more is easy. I don't think I'd want to have saved the old stuff anyway, as the bezel gets slightly bowed and so adhesiveness becomes a major factor. Better to get new tape.
The bezel went on cleanly, the project was a success. I took pictures throughout the process and will post a guide.
さんによる
コメントを追加
This guide should help you: MacBook Pro 13" Unibody Mid 2009のフロントディスプレイガラスの交換
このアンサーは役に立ちましたか?
スコア 2
コメント:
I assume you're implying that the procedure for removing the AG bezel is the same as removing the glass?
さんによる
コメントを追加
回答を追加する
murdercitydevil さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 7,688
