Apple iPhone 5cは2013年9月10日に発表されました。このデバイスの修理は前モデルと類似しており、スクリュードライバーとこじ開けツールが必要です。GSM か CDMA、8, 16, 32 GB 、色は白、ピンク、黄色、ブルー、グリーンがあります。
1546の回答 すべて表示
Stuck on iTunes, Are my hosts files ok?
Hi, I have a 5c in today, it had a new full screen fitted and when I had finished I was prompted by the itunes symbol when switching it back on, I am not sure if this was already in recovery mode as the lcd was fully broken, my guess is whatever broke the screen caused the itunes mode too?
I am following some instruction online on how to get around the error code '3194' which is what I get when I try restoring the 5c, here is a copy of my hosts files, are they okay? I have played about with them in the past so they may need editing abit?
  1. Copyright (c) 1993-2009 Microsoft Corp.
  1. This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
  1. This file contains the mappings of IP addresses to host names. Each
  2. entry should be kept on an individual line. The IP address should
  3. be placed in the first column followed by the corresponding host name.
  4. The IP address and the host name should be separated by at least one
  5. space.
  1. Additionally, comments (such as these) may be inserted on individual
  2. lines or following the machine name denoted by a '#' symbol.
  1. For example:
# 102.54.94.97 rhino.acme.com # source server
# 38.25.63.10 x.acme.com # x client host
  1. localhost name resolution is handled within DNS itself.
# 127.0.0.1 localhost
# ::1 localhost
74.208.10.249 gs.apple.com
#127.0.0.1 gs.apple.com
#127.0.01 gs.apple.com
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメント:
Anyone?..???????
による
コメントを追加
MacBook Battery 修理キット
最低価格 $69.99
Buy Now
最低価格 $69.99
Buy Now
1回答
This is the one i'm currently using:
  1. Copyright (c) 1993-1999 Microsoft Corp.
  5. space.
  1. For example:
127.0.0.1 localhost
And this one is what was originally in the file when I installed itunes:
  5. space.
  1. For example:
# ::1 localhost
この回答は役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Kbobble さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,608
