メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2201回答 すべてを表示
water damaged iPhone isn't working after replacing and cleaning (isopr
I replaced the battery, logic board, cameras, speaker, antenna and cleaned the contacts or the whole parts in isopropanol over night. Let it 2 days for dry and put them together yesterday.
By connecting with my Notebook the connection/synchronisation was working. So I could see my music and photos. But the screen stayed black and I could not enter the pin.. While the connection the signal sounded constantly. Where is the problem? Do I need a new battery or new speakers? What can I do now?
Thank you in advance,
bne
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
bne, sounds like you need a new display. Of course, it is also possible that you have shorted out the backlight circuitry on the logic board. Start with a new display assembly and reevaluate. You mentioned in your question that you already replaced the battery, so no reason to replace it again.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
bne さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 12
過去 30 日: 13
今までの合計 83
