メインコンテンツにスキップ
モデル番号A1288/ 8, 16もしくは32 GB容量
451回答 すべてを表示
iPod dropped in Toilet, damaged by water, won't turn on
I have an iPod touch 2nd gen 16gb. I accidentally dropped it into the toilet. Don't ask why. It worked for 2 minutes, but then stopped working completely.
I cannot bring it to Apple support because of the water damage indicator.
If anyone could help me in the right direction on how to figure out what's wrong, and how it is fixed.
It happened in late April. I put it into rice and blow dryed it. No dice. I got a new iPod, but I would like to see if I could fix my old one. It looks fine from the outside (maybe not the insides of the ports, I don't have the best eyesight).
Thanks for your help
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
3 件のコメント
Water damage is the bane of iPod existence. It is very difficult to tell what the exact problem is without just replacing parts one by one, which can get pretty costly.
さんによる
But I would like to know how I would get the iPod emapart enough to tell what's wrong without destroying anything, so then I can calculate the cost of the replacment parts and see if it is worth fixing it.
さんによる
Best way to get an estimate on the cost is to test your components. Then see which ones need replacing. Use the guides to the right to see how to take it apart, just remember Be Careful.
さんによる
コメントを追加
3件の回答
ベストアンサー
Use the Guides
right here there's 6 to choose from.
If this answer was helpful please remember to mark it accepted.
Good Luck,
N
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
Use a multimeter and see what component still work. When you find out what the problem is then purchase your parts from either this site, www.etechparts.com, or www.idemigods.com. What probably happened was when you had it on it shorted out. You should have left it off or turned it of immediately then put it in rice.
Good Luck! Brendon
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
What should the multimeter reading be?
さんによる
If he took it apart he could test the current on component. No current = Dead component
さんによる
コメントを追加
My sister dropped her iPod touch down the toilet and the screen won't turn on can I wrap it up in bubble wrap and will that help soak up all the water
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Zach K さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 6,017
