メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
home, lock button failure, gsm module failure after screen replacement
hi!
i replaced the screen of my iphone 5 and did it really gently, so i didn't damage anything inside. But after the replacement the home, lock buttons stopped working and also there was no gsm signal. telephone is constantly in recovery mode, but it is possible to bring it from this mode using tinyumbrella, for example. i brought my phone to the best repairment center in town and after 2 days of inspection they said that they couldn't help. they didn't find any damage inside, they tried to change all buttons new screen but it didn't work either. telephone doesn't work also with old cracked screen, but it worked before i changed it. So i would be glad if someone help me, or give me a contact of a person who knows how to fox the phone :)
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
Pry damage to the motherboard from prying battery..
Look under the long black interconnect cables just opposite sim tray there will he missing components
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hi Sergei,
This is classic pry damage from prying the battery on the logic board side, I see it every day.
I fix mail in iPhone 5 pry damage constantly, including International phones. We can restore your home and power button function, guaranteed.
I'm worried about your searching no signal problem though. Look very closely at the glass chip located on the edge of the board just under the SIM tray---if there is a slight crack or chip on this chip caused by a slipped screwdriver on the nearby screw hole, then this could be the source of your searching no signal--I've seen that twice.
First, however, rule out common causes of searching no signal like date/time problem.
I will post a link to my pry damage repair service so that you can inspect your phone to see if it matches the damage in the pictures.
http://www.mommyfixit.com/iPhone_5_Pry_D...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
What in God's name is a GSM module?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Sergei さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 267
