メインコンテンツにスキップ
二輪車、自転車の修理ガイド。特定のモデルを検索するか、関連ページのセクションでトラブルシューティングのwikiを参照するか2つの方法を使ってガイドをご利用ください。
139回答 すべてを表示
How do I repair the sound coming from the gears?
I do not know from which exact part of the gears is the sound coming....all i know is that when i shift into the first gear then the bike starts making some sound and does not change till i give it a shake.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
1件のコメント
Is the sound just a constant clicking?
さんによる
コメントを追加
4件の回答
選択されたソリューション
If you only have the problem with first gear, then problem may just be with the derailleur limit screw adjustment. If you study the derailleur carefully, you should notice 2 special screws that limit the distance the derailleur can move inward or outward. When the derailleur reaches one of those limits, part of it hits against one of those screws, preventing further movement.
So first off, turn the bicycle upside down or put it on a stand so you can see what's happening while you turn the pedal and try to shift.
As you try to shift to first gear, see which screw is limiting the movement. Then try turning the screw a half turn in the direction that allows more movement. Try shifting in & out of first gear now. If the chain still rattles without shifting into first, turn the screw another half turn and try again. If you keep on turning the screw, you'll eventually get to the point where the derailleur can move too far and push the chain past the gear (and possibly off the entire sprocket set). Just pay attention to what the derailleur is doing and this shouldn't be a problem.
このアンサーは役に立ちましたか?
スコア 7
1件のコメント:
+ good description
さんによる
コメントを追加
I agree with cityzen, but also derailleur hangers are often knocked out of alignment without the owners knowledge. Realigning derailleur hangers require special tools and a true rear wheel. If limit screws are not the problem I would check the alignment of the derailleur hanger by putting the bicycle in the largest chainring on the crankset and the smallest gear in the rear. Visually draw a line from the smallest gear and make sure the smallest gear in the rear lines up vertically with the pulleys in the rear derailleur. If it does not then you may have a derailleur hanger alignment issue. Other things that can cause drivetrain noise are a worn chain, bent derailleur cages, derailleur cable tension, and worn out pulleys on the derailleur. Good luck!
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
It is irresponsible to offer suggestions to solve this without putting my hands on the bike.
You say that it occurs when you are in 1st gear. Is that 1st gear on the wheel AND at the crank?
What sort of sound are you talking about?
Does it happen while you are pedalling only?
Have you crashed the bike onto the right side of the bike?
What is the condition of the chain? Rusted or kinked, or any stiff links?
Why would the sound stop if you shook the bike?
There are so many questions that need to be answered. Offering a solution such as adjusting the limit screws is jumping to conclusions without doing the proper investigation. I would never tell a client that I know exactly what the problem is without having put my hands on the bike first. A good mechanic does exactly that. Asks relevant questions and does proper investigating to solve problems.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
It needs a little bit of repairing. Here is a GUIDE.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I don't know what to do I just bought a brand new cycle and the gears are idk what like bruh when I shift gear the gear makes so loud noise and it's forever and then you have to switch back to make the noise disappear and the clicking noise while pedaling also happens in certain gears like how the heck do I fix this like I just bought the cycle man
さんによる
コメントを追加
回答を追加する
gautam agrawal さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 25
今までの合計 18,834
