メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
Can I install this iPhone 5s home button on my iPhone 5?
Hi guys,
I was looking online and why not, I thought having an iPhone 5s style home button for my iPhone 5 would be cool. So I came across into this:
White Home Button Key Cap Replacement With Rubber Gasket Pad For iPhone 5S
So, if any of you guys can help me out and let me know if it will work on my iPhone 5 it would be greatly appreciated!
Thanks.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
4件の回答
最も参考になった回答
You can buy a 5er homebutteon looks like 5s it works for sure. I will have not the fingerprint
feature but looks like 5s.
Have fun.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Thank you, I know that it wont have fingerprint feature but it will look like a 5s.
But I am a little skeptical because the description says "for iPhone 5s".
in fact, This one looks way better than the others 5s home button look a likes that are complete aluminum. (I've been researching for a while) and even though it is not that expensive, I don't want to get my hopes up and go into the hassle of opening up the device for nothing.
Thanks.
さんによる
Check this out here you can find what you are searching for.
Have fun.
http://www.ebay.com/sch/i.html?_from=R40...
さんによる
コメントを追加
can I Install the iPhone 5s Homebutton on iPhone 5C too ?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
generally they make custom home button for all sorts of iphone.... they even make this button for iphone 4 ... just check that it will work in iphone 5c before you buy
さんによる
コメントを追加
it doesn't work because you would have to add different software to the phone. I have a 5c and i just bought a fake touch id home button. I hope this helps!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
software and hardware as well. The iphone 5 and 5c have a really simple way of connecting to the home button, with two electrical; contacts. when you push the button it completes a circuit. I have "hit" the home button many times by bridging the gap between the contacts many times with a metal object in order to go home while testing a disassembled phone. And anyway the iphone 5s has a complex data cable for its home button.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Alec さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 5,064
