Need to find the BSDL file.
Hello,
I have a short on a MBP 13" Late 2011, causing the fan to run continuously at full speed.
The board seems to have suffered from liquid damage, and someone previously attempted to repair it (marks of probing and poking, not sure if they did any reflow attempts as the board is gunky / dirty).
I located a short on one area of the board, that may be due to 1 or may be several charging capacitors, having 7ohms impedance (too low) that will need: removing and testing individually? (I'm asking, since I dread the work and hope for a different approach), or other causes.. since so many are possible.
We have a method and device that will help determine the cause of the short, but we need the BSDL file for the board, and would appreciate if anyone can help us find it, or at least determine the identification number and make/model of the board to help us search for the proper file.
Or if someone can suggest an approach to zero in on the short.
Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
