Magsafe shows very dim green light, no power on
Magsafe adapter only shows very dim green light, Macbook does not respond.
Tried new magasafe adapter and new DC in board, no change.
On the logic board, there is a small white surface mounted component beside the video connector. My guess is that its a fuse, all other similar components show continuity, except for this particular one. When plugged in, I get approximately 16V on the top end of the component, and only a small amount of voltage gets through to the other side.
Am I correct in assuming that its a fuse, and would replacing it possibly repair the board?
Thanks
Can you take a good picture of it and post it for us to see what you are referring to.
Dan さんによる
Thanks Dan, picture uploaded.
Dmak さんによる
