メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2191回答 すべてを表示
Noise cancellation mic not working, what to replace?
Hi, the noise cancelling mic on my 4s doesn't work. There is white noise when playing a video I record and the actual sound is inaudible. The only time you can hear the actual sound is when you speak directly to the pinhole next to the headphone jack. Speakerphone and camera are the one that don't work, regular phone, Siri or Voice memo work.
I tried resetting the phone, cleaning the pinhole with a needle, blowing dust out of it but nothing worked. Does anyone with similar trouble found a solution ? Taking it to an Apple store is not a solution I will be looking for since it is out of warranty.
The DIY tutorial I saw is for the iPhone 4 so I'm not sure if I need to replace the Power & Sensor cable as it may not have the same components for the 4S.
Thanks for you help.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
Hello the noise cancelation mic on the 4s is located on the headphone flex you could try replacing that
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Ok thanks I'll try to replace it.
さんによる
コメントを追加
Did it work?
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Sorry I haven't tried it yet, I'm not at home for now. I'll update when I replace it.
さんによる
I've just switched around the metal frame that holds the noise cancellation mic with the frame of a bricked phone and it worked so the change of flex worked for me.
さんによる
コメントを追加
回答を追加する
john cartersh さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,570
