Xbox 360 S wont stay on
How can I fix my Xbox 360 (slim)? It keeps turning off. It cuts off 8 to 10 times before it comes on for good. The eject button doesn't work and I have to turn on the console from the controller. What can I do?
Have you tried a different power supply? The one you have might be bad.
このアンサーは役に立ちましたか?
All those things, the start button, the eject function, and the on/off symptom involve the same part (the faceplate). To me, it sounds like you have a faulty or loosely connected faceplate ribbon. If it still doesn't work correctly after completely disconnecting the faceplate and its ribbon from the motherboard, try replacing the faceplate. It's easier to replace the entire faceplate than to replace only the ribbon. May God bless you and your family today!
Xtreme Games Dallas
このアンサーは役に立ちましたか?
I forgot to mention that the RF Module (the little green board your faceplate is connected to) can also be defective and easily replaced.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 3,041
1件のコメント
This question was migrated from http://meta.ifixit.com/Answers.
iRobot さんによる
