メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2193回答 すべてを表示
My callers hear an echo, I dont
hi everyone who calls me says they can hear a bad echo of their voice .. yet i hear nothing?
looked on some forums..they blame the case..took it off still happening...some even suggest me to change my cellular network...still happens, wondered if u had any advice?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
最も参考になった回答
My first thought was the cellular network. Troubleshoot the network by talking to different people on different networks.
If they hear you fine, your mic is good.
If you hear them fine, your ear speaker is good.
It doesn't sound like it's your phone, but I've never heard of this issue. Maybe someone else has more input.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I know this is a good while now but here is my 2 cents worth as i have encountered this a fair few times now. i have found that the echo goes away when battery cover is removed but reappears when pushed back on. i wanted to get to the bottom of this as it did not seem like a hardware failure.
firstly (the obvious)remove any protective case and check if same issue.
then for only testing temporarily!! ,try sticking a pin or covering up best you can the tiny hole for top mic which is located beside earphone jack.
if you find the echo goes away then try next step below (you dont want to permanently completely block this hole as you will have poor speakerphone and video audio quality).
The proper fix would be to put a thin layer of foam in between the top mic and black rectangle mount shown in image .
it can be done carefully with only having to remove battery cover. a thin screwdriver in between these areas will prise and give some slight access. Best to work from left hand side of top mic incase you rip cable on right hand side
i would advise trying this before even looking at a full headphone jack or dock replacement
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
do you think this would work on a Samsung phone?
i am having a similar issue with the s6's and s7's
さんによる
コメントを追加
回答を追加する
Dave さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 602
