メインコンテンツにスキップ
Repair guides and support for wireless and wired Apple keyboards.
206回答 すべてを表示
Water spilled on keyboard and now rows of random keys arent working
A few days ago i accidentally spilled water on my on my keyboard. It did not appear to be alot of water at the time but now it seems like it has been soaked as about an hour or two later keys stopped responding.and i noticed water dripping off my keyboard when i lifted it. i tried to dry it off but it has not improved after about a day and 3 quarters. it appeared to have shorted out certain keys and some around it as columns of keys. it it possible it will fix its self by drying out? or if you think its possible that it can be fixed at all (by an apple genius or me )
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 26
18 件のコメント
I have the same problem except buttons on my keyboard randomly activate without anything
さんによる
After I spilled water on it , blow dried it. And I come back like 4 hrs later and some of the letters don't work, and every two minutes airplane mode turns on and off. its driving me insane I cant do any work
さんによる
I spilled a whole bottle on m computer and the whole key board is not working I told my parents its just a bad computer and to get a new one if I do not find a solution soon I will be in ver big trouble
さんによる
All my keys on my key board dont work but I cant find a video on how to fix it whithout taking apart the computer
さんによる
yeah guys i have a lot of those problems too. Im waiting to see if it will fix if it dries out but for now im using the touchscreen keyboard on my laptop. Lots of computers dont have tc so probably the best thing to do is unfortunatly us a usb keyboard. It would be a lot of work to switch out your key board! Good luck on this case tho hopefully u find a way around it or a solution.
さんによる
13件以上のコメントを表示
コメントを追加
4件の回答
ベストアンサー
A new one from Apple is $49. http://store.apple.com/us/product/MB110L...
A tech is going to charge probably $60 to look at it. Here's my teardown of the wireless keyboard and as you can see, there's very little in it that could possibly be repaired: Apple Wireless Keyboard (A1255) Teardown
After you get your new keyboard, spend $1.99 and get a cover: http://www.amazon.com/Topcase-silicone-k...
このアンサーは役に立ちましたか?
スコア 5
4 件のコメント:
Will a bath in desinfectant or medical alcohole render a working A1243 defective?
さんによる
i left my laptop dry by itself for a month now the only keys that dont work properly are f2 f3 asdfujnb and the numbpad
さんによる
Needs a serous update do to the passage of time, (this comment 2021)
1.) this is a USB Keyboard
2.) finding a keyboard this old online is a real risk, Expect nothing less than $100 at amazon.com . Many photos and complainants of damaged junk being sold, the one I bought is are delivered in terrible condition.
3.) Water damage is beyond the for the average DIY as I understand. I wasted a lot of time trying to to false hope.
さんによる
After spilling tea on my aluminum wired Apple keyboard (and wiping it down with cleaning spray), all my keys were doing crazy things so I put the keyboard upside down on a heating pad on high for 1-2 hours and it works fine now!
さんによる
コメントを追加
最も参考になった回答
I had the same problem with a USB keyboard, even if there had been very little liquid poured on it. All the keys stopped working, but I decided to try something, as the keyboard seemed dead anyway. It has now spent about a week on a radiator (a thermometer shows between 20 and 25°C (68-77 F°)) , and today some of the keys are responding again. It does a little "clk-clk" sound at the beginning, as if the keys had been glued or something, but they work. I read somewhere that the problem occurred because liquid was trapped between to layers that make contact under the keys, so it could take a while before the whole stuff was completely dry again. But it seems like warming up gently the damaged keyboard can help.
PS: I hope you will excuse my $@$*!& English; I'm French and don't write very often in English. ;)
このアンサーは役に立ちましたか?
スコア 7
3 件のコメント:
I have been waiting about 18 months. All keys work but z-? and the spacebar - yay.
I've currently leaned it against the wall vertically. Back in 18 months.
さんによる
I was just cleaning it with a soft damp cloth. Never drop any water. But now the keys QWER are not working. Sad.
さんによる
i spilled a little bit of water on my keyboard then i wiped the water off then went to sleep i woke up and the keys are not working just the mouse and i don't know what to do!
さんによる
コメントを追加
If you spill any liquid onto the Apple Aluminum Wired Keyboard, you have a ZERO chance of taking it apart successfully, due to the fact that if by some miracle you were able to use a hair drier to heat the bottom white plastic and pry it off of the aggressive adhesive from the spacebar to function-key side without bending the metal sheet fasted to the plastic bottom or the opposing metal sheet and aluminum keyboard frame, you will find that the upper metal frame holding all the keys is spot-welded to the aluminum frame with 147 individual spot welds.
The only way to possibly resurrect this keyboard is to soak it with vigorous agitation immersed in 2-3 changes of STEAM DISTILLED water (not reverse osmosis or filtered water that still contains salts). Drain off the water, carefully swing the keyboard around outside to centrifuge out as much of the distilled water as possible, and then set it on something warm with the keys side up for a day or two to completely dry it out. This way you rinse out all conductive salts, and dry out all moisture, which could cause oxidation and conductive corrosion. Even better if you have a friend who works in a lab, put it in a vacuum drying oven at very low heat overnight or in a freeze drier overnight. Good Luck.
このアンサーは役に立ちましたか?
スコア 4
9 件のコメント:
So I accidentally spilled a tiny bit of water and keys wouldnt type I was wondering what to do to fix it
さんによる
that is the most ridiculous answer I have read to date on here...yeah just got get your buddy at the local lab to hook it up to the centrifuge LMAO! very helpful!
さんによる
I didn't say to put it in a centrifuge. To be more - clear one should swing it around in a large circle to help drive the water out by centrifugal force.
さんによる
your best bet is going to be if you can get it apart and clean it, its possible its permanently damaged but its also possible theres corrosion bridging contacts witch could be cleaned if it comes apart
さんによる
you can't take it apart without destroying it, look at the teardown.
さんによる
4件以上のコメントを表示
コメントを追加
I spilled chilli liquid with sweet (sticky) sauce on my new Tecware Spectre Pro 104 keys keyboard. its about USD67. Like the other guy here, i had hope and spent like 8 hours total to try and save it. this is my first ever mechanical keyboard, i wasn't about to give up on it!
The whole 40% right side was affected. And because it is not just water, it will leave a residue, i had to pluck out every key and switch to see how far the liquid flowed to the left side.
And this is the first time i realized I ABSOLUTELY HATE taking out switches. I don't understand why switch designers made it so hard to plucked these switches for the first time. I literally used all my strength and the tool will just slip off and scratch everywhere else from the sudden slip. I tried a few times and it still wouldn't come off! i had to rest a few times. even the switch removal tool metal part bends! so there's no grip from the tool other than my pure strength!
While plucking with the switch removal tool, I grabbed so hard that I broke almost all the switches in the non-critical area (there's a short thin plastic that serves no purpose, one pinch and it bends and broke).
Because without going full super saiyan 4, i literally couldn't pull it out. I literally cursed and swear.
Digress, this reminds me of the time i went to a dentist to get my milk tooth out, and they inject me with anesthesia and the nurse yank my tooth left and right ,and left and right and she couldn't pull it out. So she got another nurse to come over and BOTH of them yank my tooth with double power, while my head turn on my neck like a joystick.
So that's how i felt when i try to pull out switches.
i used a Q-Tip dipped in soap water to wipe each key and switch twice. The chilli liquid was sticky and oily, it was a nightmare. some RGB lights have disappeared. some keys keeps repeating or typed on their own, meaning the liquid inside is still there. I wanted to tear down to clean the PCB, but the design prevents me from doing so. so the most inner part that has the liquid forever can't be cleaned. some keys died permanently. and some RGB also died.
i saved about 80% of them. but it is no longer useful for me. i need my 104 keys and it is not as useful now being a 68 keys keyboard. the right arrow key died, the no. 6 key died and the numpad key died, so i can never press right to move the text cursor. Page up and page down and end key died. those are very useful keys i need.
so it was not worth the time and effort. on hindsight, these switches are a nightmare to pull, I will just get another mechanical keyboard next time, since i couldn't save it to my usefulness anyways. Now i use keychron with linear switches and i absolutely love it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
weridpan さん、ありがとうございました!
統計データ:
過去 24時間: 20
過去 7 日: 172
過去 30 日: 822
今までの合計 394,879
