メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
This device is T-Mobile's version of the Samsung Galaxy S II. It was released in October of 2011. It was the first Galaxy to include T-Mobile's new expanded 4G network.
20の回答 すべてを表示
Why isn't my phone charging?
I was charging my phone early this morning before my game and before i unplugged it, it shut off and wouldn't turn on. Phone was at about 70% at the time and i still can't get the phone to charge. Please help!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメント:
You can always get the wireless charger if the USB port isn't working. That's what happened with my phone is the USB port got wet and now it won't charge I have to charge it with the wireless charger now. Or I have to blow dry my phone before I charge it or else it won't work. I hope this helps.
さんによる
コメントを追加
Nintendo Switch 修理キット
ゲームを再開するための、早くて簡単な修理キット
Switch 修理キットページへ
Switch 修理キットページへ
2件の回答
最も参考になった回答
jesseornelas72, check your charger to make sure that it is working. Try a different cable, and check your port for any debris corrosion and bend/broken pins. If all that checks out replace the battery and reevaluate. If none of that works you could be having issues with the power management IC or the charging coil itself. Hope this helps, good luck.
この回答は役に立ちましたか?
スコア 1
コメントを追加
Sorry i have ignored the phone brand and model,
This pic is for the Galaxy S 2, and i have marked the Charging dock.
この回答は役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
jesseornelas72 さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 448
