メインコンテンツにスキップ
モデル番号はA1238/80、120、160GBハードドライブ/ブラックもしくはシルバーメタルフロント
904回答 すべてを表示
Displaying 'Charging please wait with yellow triangular icon'.
Hello guys. I have an ipod classic 80 gb which shows 'charging please wait' red color on left and yellow triangular exclamation mark. I tried charging in Apple certified ipod 2.0 usb charger and in my PC too for more than 2 hrs and it doesn't startup and I checked the hardware by opening physically looks fine. I would like to get help from anyone telling me how to troubleshoot this problem it would be great honour for me :-)
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
最も参考になった回答
Anzar, first make sure that the dock connector is clean, no corrosion and no debris in it. If it looks okay, replace the battery and reevaluate. Check the battery connector carefully. This model had issues with the battery connector coming of the logic board. Use these guides to work on your iPod. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Sir I swapped the battery of my brother's ipod classic 30 GB to my ipod and checked the charger it doesn't connect and charge when I remove the charger screen comes on and when connecting to my ipod dock speaker it gets connected and charges my brother's ipod battery. And when I installed my ipod battery to my brother's ipod it charges in both dock speaker and charger but why my ipod not charges in the same charger when i swapped the battery? Earlier was not connecting to my computer but now when i swapped the battery both ipods connecting.
さんによる
Sounds more like an issues with the dock connector or the logic board, check for broken bend or corroded pins in the dock connector.
さんによる
コメントを追加
It works fine when connecting to dock speaker and computer but the main apple wall outlet charger does not detect and charge when i installed my brother's ipod battery. The connector and pin everything looks fine physically.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Anzar さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 2,445
