Check this
https://ibb.co/mD9t8v
try to check the track at this tp fourth with a multimeter. This track is devoted to checking function usb ic function, in other words u2 in iphone 5. if among the four or all tp contains a small or large ground, means ic u2 short circuit or damaged and immediately replace it. if examined does not contain ground, instead of u2. the size of the short circuit must be true if damage to u2. if there is no short circuit on the fourth tp, please check the battery connector. usually at the time of replacement batteries for the revocation of the battery connector flex too hard and less conscientious, could make battery connector on the pcb become shaky, as a result the battery is not detected by the gas gauge and the circuit is directly protected by way of breaking the current to the battery lines. iphone will reboot loop. if this is the case, then immediately re-solder on swi bat and bat pin ntc. Safety plug the battery into the meeting, in order to avoid a gap between the spark plug.
I am happy to join here, to share knowledge and experience sharing.
you are all professional technicians?
solve problems and continue to learn ,,, good night ...
9 件のコメント
Why not go somewhere that you can replace u2?
It's not much easier? :)
Fixmart Laboratory さんによる
Just for your knowledge ...
Component u2 that is not good cause high current consumption, overheating.
Difficult and uncomfortable to use the phone like that.
If you do not correct it, instead of buying batteries is better for you to buy an old Nokia phone, that will cost you as one battery for the iPhone 5, and Nokia do not have u2 and the battery will stay weeks LOL :)
send my the iphone i will send you 10 NEW Nokias!
Do you know where I can replace the U2 IC for the iPhone 5 in Europe ?
If not, Do you have a step-by-step review to do this reparation ?
Thanks
majd ghazaleh さんによる
Hi, I can replace u2. That's what kind I usually do. Where about are you if I can help
aqi さんによる
Can we replace the ic board in iphone 5s. The shopkeeper is fooling me from 2 months saying we are not getting the matching IC Board. Is it true apple has such unmatching ic board issue ?
Please help me with my question !!
Dinesh Jain さんによる
4件以上のコメントを表示
