メインコンテンツにスキップ
Repair information for the Bose QuietComfort 2 acoustic noise-canceling headphones. Released in 2003. Model number: QC2.
How do I take the Silver cover off
I have a problem with the right headphone and I suspect a wire issue but I need to take the cover off to be like this picture:
http://hackaday.com/2013/12/07/repairing...
Any help is geatly appreciated
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
Sam soud, to get to the wiring, you will have to remove the parts on the inside, not the outside (silver cover) . Check this quick and dirty guide for a similar model. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Thank you for the hint!
I Can cut the wires and replace them from the inside , but it might not work,.
As you can see that the wires extends to the electronic board, I want to reach to the board in order to see if the wires are disconnected ( less likley)
さんによる
コメントを追加
回答を追加する
Sam Soud さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 929
