Would this part that broken cause intermittent wifi?
Hi this part is broken in half would it cause intermitted signal in wifi
This is for cellular diversity and GPS. Wifi is at exactly where it was.
このアンサーは役に立ちましたか?
I know it for GPS but would this cause wifi to turn off and on?
Very unlikely
I think it could be possible----if that piece is torn off that means this board has been under some twisting/tearing force. The WiFi chip is also located on the top of the board, on the back side reasonably near here. I think it is reasonable that whatever torque this board experienced could have also damaged the WiFi antenna traces.
このアンサーは役に立ちましたか?
Thank you yes this iPhone was accually bent and one stage and the frame needed straighing out
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 127
