Lcd replaced and no backlight
I changed my lcd on my iPad mini but now my backlight isn't working I can see the display come on I can open and close apps but no backlight can u help me
You will need to have your backlight filter replaced. Someone needs to solder a new filter on the logic board.
このアンサーは役に立ちましたか?
Thanks
Any recommendations on where I can get something like that repaired I live in Orlando Florida and I'm going to ship it out
Look for the user jessabethany on this site. She should be able to help you out.
Try lifting the motherboard from the battery contacts for a few moments and then reseat it again ....sometimes I think this discharges static or just makes a better contact. Make sure power is off and to be safe disconnect the cable from the daughterbd ( comes across between the battery segments). This has worked for me on several repairs.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 136
