Hi,
Ipad is home button can work again in many ways :
Fix your iPad Home Button Step-1:
This problem is called the Portrait view/landscape view which is very much has the blame to get iPad home button not working.
In this problem you need to follow the steps below that can help you to solve it.
1# View your iPad to portrait mode and press a long hold to the home button.
2# Now turn your iPad to landscape mode while holding the home button
3# Now again change the view mode from landscape to portrait.
4# While doing this process you need to be sure that the screen of the device must rotate.
5# If the iPad screen rotate while changing the view mode which means that problem has been fixed so now release the home button which was press and hold from the start.
Fix your iPad Home Button Step-2:
This step is known as the assistive touch, in this step you can create the Home button on your iPad screen with the simple steps only you need is to follow and apply
1# First of all goes to the setting of your iPad device.
2# now tab on the Accessibility
3# Turn on the assistive.
4# At the right corner of the bottom of your iPad screen click the icon which appear after you complete the above step and than select home screen.
5# Now you can see that at the right corner in the bottom home button will be located.
6# You can also change the place of the home button by dragging it with the finger hold and tap.
Fix your iPad Home Button Step-3:
This method works most of the time where we have to recalibrate the home button.
In this method you have to follow the below steps carefully to get rid from this problem and make your iPad work properly.
1# First of all you need to press and long hold the power button of your iPad.
2# after you completed the first step “slide to power off” will appear on your iPad screen, so release the power button and then hold the home button.
3# This process of holding the home button will only be stop when the home screen appears.
Fix your iPad Home Button Step-4:
This step is called the Clean the home button, this problem is most rare in iPad home button because of the debris, dust dirs. So instead of giving your iPad to the repair service center you simply clean the button.
You need things to clean the home button of iPad.
1# Alcohol: to clean button used rubbing alcohol.
2# Cotton: Pour few drops on the cotton swab to clean the button.
3# Finger: put a two drop of alcohol on your figure and rub it on the button after than push it around the corners, so the dirt which has jammed the button can be easily removed.
Fix your iPad Home Button Step-5:
This one is the last method of repair your iPad home button which is called 5-finger gesture, apply this method only when the previous method didn’t fixed the iPad home button problem. Follow the steps below to get rid from this button problem.
2# Turn on the Multitasking Gestures function.
3# Now go to the home screen and spread your hand on the screen and then placed your five finger on the iPad screen. You need to punch them all in and then grab them together to function this process.
1件のコメント
I had the same problem, then my wife found this solution. We did not have any rubbing alcohol so used Witch Hazel instead. So happy that this worked. Thanks very much.
Steve Ingham さんによる
