メインコンテンツにスキップ
The third generation of the Samsung Galaxy tablet with a 7-in. screen announced on June 24, 2013. Repair of this device requires screwdrivers and prying tools. The device is available in white or gold brown with 8, 16, or 32 GB of storage, and includes a microSD slot that can hold up to an additional 64 GB of memory.
120回答 すべてを表示
My screen is not responding to touch/can't power off.
My screen is not responding to touch which in turn, I cannot power off my tablet. When I press and hold the power butter, it will eventually restarts, but when it comes back up, still no response to touch. If anyone has any advice; I'm listening. Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Lett, sounds like a failed digitizer. The digitizer and the LCD are adhered together and you will need a heat source (heat gun etc.) to separate. Not an easy job, but doable. Check this video to show you how to do it. The digitizer and the adhesive strips are available at places like this.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Sounds like your digitizer has gone out and unfortunately with the tabs you have to replace the entire lcd and digitizer assembly and it usually ends up being cheaper to replace the whole device!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Lett さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 357
