Why is my hard drive not being recognized?
It won't boot. The hard drive is not recognized in Disk Utility or in a fresh install. I took out the hdd and plugged it in another computer and it is fine. The optical drive works fine, so I doubt it's the logic board. I think it's just the SATA power/data cable. I heard that it could potentially be fixed by putting some tape in between the drive and the cable to force the connections closer together. I will try that tonight and report back. If it's not the cable then I believe it's the logic board. I'm not interested in spending $600 on a new board, but I would be willing to remove the optical drive and use the adapter that allows for a second HDD to be installed there. So I guess I'm asking if anyone has any other ideas, but also I want to make sure that if I replaced the optical drive with my HDD that I could use that as my only drive. Everything previously says that it is meant to be used for expanded storage, but I want to confirm that it can be the boot drive as well. Thanks!
この質問は役に立ちましたか?
1件のコメント
The tape didn't do anything for me. Didn't show up in Drive Utility, or during fresh install.
HoratioDUKEz さんによる
