Why aren't my MacBook Pro's internal speakers working?
About 3 years ago I spilled milk on my MacBook Pro. It was fine until a few weeks ago when it wouldn't turn on. Genius bar said it would take $800 to repair. Opened it up and scrubbed down all parts with rubbing alcohol and let sit out overnight. Started from logic board with tweezers and I heard the startup chime. Booted up as usual and brought me to login screen. Keyboard was not functioning in certain areas, but the MacBook was otherwise normal. I plugged in a USB keyboard and that worked fine. Sound was working and everything was normal. However, the sound stopped working yesterday. No startup chime or anything, and when I went into system information, it said that no internal speakers or Microphone were present. It does not recognize headphones either. The internals are not corroded so far as I can tell. I've taken out both speakers and rubbed the connections with isopropyl alcohol. What could be wrong with it and how do I fix it?
This is what I see when I go to system information and go to the Audio tab:
この質問は役に立ちましたか?
7 件のコメント
Update:I received the keyboard and installed it. Still no sound/usb. I quit the sound driver and restarted the computer. I reset the PRAM and the SMC. I updated all software and I did a complete reinstall of the operating system, to no avail.
Robert さんによる
Not sure what could be causing both sound and USB problems.
Robert さんによる
I added an image of what happens when I go to system information and click on the audio tab. It knows that it should have internal intel speakers but it says that its value is 0, which I believe means that the Mac doesn't recognize that the speakers are connected.
Robert さんによる
Everything else besides sound and USB is working fine.
Robert さんによる
UPDATE: I just ran extended testing with Apple Hardware Test and it said "No Trouble Found". I'm not sure, but does that make it a software issue?
Robert さんによる
2件以上のコメントを表示
