メインコンテンツにスキップ
2010年4月発売。2.4, 2.53 GHz Core i5 or 2.66, 2.8 GHz Core i7プロセッサ
591回答 すべてを表示
締切られた回答
MBP cannot start. Powers up hdd then shuts Down
Hello i was browsing the internet on my mbp (plugged to power) when it suddenly went dead. When i try to turn it on, it powers up for maybe 2-5 secs (ligth in the White led, hdd starts spinning) then shuts Down. It never makes it past Black screen to the Grey screen.
I have put ssd in the computer in the normal hdd spot and mounted hdd in the spare where dvd. Drive usualy sits, using an adapter. This has however been working flawless since april.
I have tried resetting smc by pressing L-shift + ctrl + option and power Button at the same time.
Cannot reset pram either.
Tried checking hdd and ssd connections to mb, as i had read that it could cause these symptoms.
Any advice on what i could try to do?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Torben;
Is your secondary drive bootable? If so, restart, and hold Option key when chime sounds or screen turns on. After a few moments, a list of bootable devices will appear.
- If a bootable device is available, select it for boot, and troubleshoot the problem drive.
- If not, boot to an external bootable backup drive on USB or Firewire port and troubleshoot.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Also - you did not mention if MBP running on battery or mains power. Make sure you are on either a well-charged battery or using the power adapter.
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 85
