メインコンテンツにスキップ
Nintendo DSiは任天堂 DSラインの第3番目となるモデルです。2008年後期に日本で発売されました。
262回答 すべてを表示
Power Board Connector Ripped Of From Mobo (w/ pics)
Hello,
While I did find a couple questions similar to this one, my head hasn't come around a clear answer. I was at the process of fitting a new touch-screen on my DSi and I've accidentally popped open the Power Board Connector straight out from the Motherboard. Ignoring the problem temporarily, I continued on fitting the touch-screen in which was placed successfully. I refitted all the ribbon cables and the screws back on the motherboard, but I'm left with the broken connector.
The cable should have been disconnected from the connector like this:
Using a tool like a Spudger
And opened like this
Alas, mine has become like this (excuse the poor quality)
So I believe the two options I may have is to solder (?) the connector back onto the motherboard OR buy another power board altogether (I would be more comfortable with that). However, I'm not sure if that little casing for the cable comes with a standalone power board connector; so that option will be crossed off. All in all, I would highly appreciate if someone dusts off the confusion!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Elias Raed, your picture is very hard to interpret. If you broke the connector of the board you will have to either solder it back on (depends on the condition of the traces.) If you broke the plug you will need a new power board. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Hello oldturkey thanks for the fast response!
Unfortunately, I did think the picture was too blurry and I cannot get a decent close up. But what you stated was correct. The whole connector is disconnected from the motherboard.
The part of the logic board and the part of the power board is still connected together, but isn't on the motherboard. I do believe the traces are still in good condition and possible soldering is at need. In the meantime, I'll have someone look at this and will update ASAP.
Thanks
さんによる
Alas, there was a mistake on the comment before. Sadly I can not see any metallic traces on the body of the white socket (which sits on the motherboard).
さんによる
Soldering the wires without the connector should work.
さんによる
コメントを追加
回答を追加する
Elias さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 300
