Screen goes on and off until I apply pressure to left speaker?
When I turn my MacBook Pro on the screen will go on and off until I apply pressure to the left speaker. The system is running fine and continues to work without issues. I looked inside and there are a couple of screws missing from the case so I ordered them.
Any ideas would be greatly appreciated? Many Thanks
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメント:
hi mayer that did not fix the issue it still needs me to press on the speaker next to the tab key,to begin with ,but once it has booted up completely it seems ok ?
による
is it possible that the little pins on the mother board are not contacting the outer shell, i noticed one or two of them do not spring out like the others ?
による
Add an image to your question so we can see what you see.
による
コメントを追加
Pro Tech ツールキットを含むご注文、もしくは総額 $100ドル以上のご注文については送料無料です。
当社のショップを閲覧する
3回答
選択されたソリューション
You are pressing on the LDVS cable connection to the logic board. Open the machine up and reseat the connection. Use some kaptan tape to help hold it in place.
この回答は役に立ちましたか?
スコア 1
コメント:
による
コメントを追加
Is it possible the screws which were missing are still loose inside shorting something. Can you tell us what screws you had to replace.
この回答は役に立ちましたか?
スコア 1
コメントを追加
I have the same problem on a MBP 5,1 (late 2008). The sweat spot I have to press is right on the left of the caps lock key. I was suspecting LVDS cable too but the cable is very close to the monitor and don't go near the caps lock key.
I try to disconnect and reconnect LVDS cable but got no luck so far. I might try to remove the logic board to see on the other side.
Let me know if you find a solution for this. Thanks!
この回答は役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
roy さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 176
