メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2375回答 すべてを表示
締切られた回答
Boot loop after screen replacement
I have repaired many iphone 4 screens and have not come across this problem. I changed the screen assembly and got the phone back together and working. It seemed fine when I handed it off to the customer. Wifi was good, cellular had signal, digitizer was operating fine. I had no indication of a problem until the next day. The customer brought the phone back and said that it just shut off and only would come on if plugged in. I took a look to find that when plugged in it would boot to the ios6 greeting screen as if it had been reset but it would not move past that screen. Cellular signal was stuck at searching (witch I realize is irrelevant at this point). I disassembled and checked connections and for visible damage and found nothing. I did notice a burnt smell inside the phone but no other evidence of burning (heat,smoke, black areas on board or housing). now that I got it back together it only boots to apple and cuts off before it completes boot process then comes back on. any advise is much appreciated.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
最も参考になった回答
100% a damaged battery a new 1 will fix it ..
Had this problem before
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Battery, charging port flex and the cellular antenna/speaker in closure have been changed with known good parts and no dice. It's down to a mobo problem. Does anyone know what chips to check for power management? We're is the pmu ic?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
However, you can try to fix this with recovery mode which is a failsafe that is used to reflash your iPhone with a new OS.
A great tool i ever used to enter and exit recovery mode is ReiBoot developed by Tenorshare. Have a try. Safe freeware and won't lose data with this process.
Good luck!
Kirsty
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 599
