メインコンテンツにスキップ
Xbox 360は、2005年11月22日に発売されたMicrosoft製第二世代ゲームコンソールです。
428回答 すべてを表示
締切られた回答
2 flashing red lights, but in a different pattern than "Overheating"
Last night our Xbox 360 started displaying 2 flashing red lights. It was very odd because the console had been off and no one was playing a game, but suddenly it turned itself on and the 2 lights started flashing. We tried to shut it off but it wouldn't power down. I connected a controller to see if everything still appeared to work, and it did... no error messages, no weird behavior. A quick Google search suggested that the 2 red lights were indicative of an "Overheating" error, so we unplugged the console and set it aside overnight.
Today I plugged the console back in. IMMEDIATELY upon connecting the power cable, the console turned itself on and flashed 2 red lights again. It seems HIGHLY unlikely to me that we have an overheating issue when the console had sat, unplugged and disconnected, for about 16 hours, yet the red lights activated the second the power cord was reattached.
After more internet searching, it seems like the overheating issue is associated specifically with the lights in quadrants 1 and 3 being red (top left and lower left). This is not the case with our console. The lights that flash red have been in quadrants 2 and 3 (top right and lower left) or quadrants 1 and 4 (top left and lower right). I have been unable to find any information about what this might mean. The console still appears to work and we still haven't seen any error messages. However, the ONLY way to get the console to power down and stay powered down is to disconnect the power cord. If I turn it off, it turns itself back on within 5 seconds (usually almost immediately). Also, I tried the process for determining the secondary error code by holding the sync button and pressing the eject button. This did nothing - no flashing pattern, no other information... all it did was make the disc tray pop open. Therefore, I have no 4-digit secondary code to give as additional information.
I should probably mention that one of our dogs seems to have peed all over the console... *sigh*. Any chance this is some weird error code that means something inside is damp? Perhaps if I let it sit, disconnected, for a few days it will fully dry out and be ok?
Any help or information will be appreciated. Thank you.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
I've not heard of any error codes for dampness. If possible, try another power cord and brick.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Megan, this "one of our dogs seems to have peed all over the console... *sigh*. Any chance this is some weird error code that means something inside is damp?" will be your biggest challenge. Right now it appears that you have bigger problems than an overheating Xbox. I strongly suggest that you stop doing anything with the Xbox. Disassemble it completely using these guides. Then clean every part with sterile water and subsequently with high grade 90%+ isopropyl alcohol and a soft brush. Clean the logicboard and all connectors well. You may have to repeat it a couple of times. Your Xbox is most likely shorted out or corroded on some vital parts. Only a proper cleaning and close inspection of all the components may reveal more issues. Clean, clean and clean again, then reassemble and re-evaluate. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
So no idea what it means that the lights that are red & flashing are in diagonally opposite quadrants? It's gotta mean *something*.
I know the pee thing is a huge problem. :( I'm absolutely terrified of opening the system up, though!! I'll read through the guides - thanks for the link.
I appreciate the feedback!
さんによる
1 and 4 are usually blinking because of a general hardware error. Very hard to tell exactly what, since it will not give you a secondary code. Sorry, I wish I could tell you something a bit easier but I still think you will have to deal with the original issues first.
さんによる
nod... thanks very much, I appreciate your time.
さんによる
コメントを追加
RF module needs replace. i had two red light at top. console was shut down.just plug in. power on still two red light. worked ok. didnt get hot or freeze up. so replaced RF module .hope that helps. randy321z
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 984
