Why doesn't my PS3 have a signal on my TV?
I have a PlayStation 3 that will turn on, but it has no signal on my TV. I used an HDMI cable and have tried it in different ports on my TV. I even went back to the original cables that came with it to hook it up. What could be the problem?
この質問は役に立ちましたか?
70 件のコメント
my ps3 is doing te same now, jst wondering if u managed to get it fixed and if so what was up with it? thanks
emma さんによる
We are having the same issue. However when I hold the power button down it only beeps once. I have tried holding it down longer but then it just turns back off. Any other suggestions? It is plugged in and everything is set up correctly...it just randomly stopped working today.
Kristina さんによる
same with mine i put in fifa 13 and it froze i took out the game then it happened i couldn't turn it off and my TV said no signal?
nichole さんによる
as my tv won't let me have signal as i put in the hdmi cable into hdmi 1 and when i clicked on it it says no signal and counts down from 5 minutes then turns its self off
alex さんによる
check to make sure that the cords are certainly put in your TV
Preston Van Stedum さんによる
65件以上のコメントを表示
