do I need a replacement bulb
I dropped the flash down the stairs about 4 in total, as you do! The LCD display still works but the flash does not fire, could this be in need of a replacement bulb?
Dawn Selway, absolutely could it be that the bulb is broken, but there is also the possibility that it is something else. You will have to dismantle it and take a look for further damage.
このアンサーは役に立ちましたか?
Your flashtube assy is most likely defective.
I had mine & trigger transformer replaced by ATG.
Contact Alzo Digital, if you are in USA for help.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,639
