メインコンテンツにスキップ
The LG Optimus G was announced on September 19, 2012. It is a smartphone designed and manufactured by LG Electronics. In the US it is available through AT&T and Sprint. AT&T carries the 8-megapixel camera E970, Sprint offers it with a 13-megapixel-equipped LS970 model.
23回答 すべてを表示
Why my lg optimus g e970 doesn't turn on?
after unplugging my phone to the charger, it showed a yellow screen that said:
HW reset was detected!
DemiGod Crash Handler: HW reset was detected!
Press key to choose Dload Mode / Reboot / Fasatboot.
1) Vol up: Dload mode.
2) Vol Down: Reboot.
3) Power: Fastboot
If you choose Dload Mode,
Please do the Following action.
1) Dload Mode. Please connect USB
2) Get the ram dump image using QCT's Memory Dubug App
3) Send email to contact point or M-TDR_Leader@lge.com
after that, press the power button for 15 seconds, and the phone was shut down and will not be returned to power on..
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
1 件の回答
This may not answer your question completely, but that screen can be reached when an app crashes your phone. The part about it not being able to turn on is a little more unsettling. If you're willing to go out on a limb, you could open up the back of the case and remove-reconnect the battery.
If it doesn't boot after this, you may have to do some serious hardware debugging. Generally if your phone can't even get into recovery mode, it's a bad sign.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Carlos さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 2,681
