Compatibility of Logic Board Between PowerBooks
Would the Logic board from an Aluminum (1.67 GHz) Model fit in this Titanium PowerBook (1 GHz)?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Sorry this is general, you can research specifics online.
2 issues are key: size/shape of the logic board, and arrangement of ports.
PowerBook evolution ran in "families" (Mercury, Onyx,...) Within a family, boards were often interchangeable - I think the 400, 500, and 550GHz could be swapped out within the same screen size. Newer/faster processors, more features, redesigns meant later incompatibility.
Also, the ports on the logic board need to match with openings in the case; if your board has all ports on the side but the case only has openings on the back, it will be difficult to plug in anything.
Another example: I have a 17" PB 1.5 GHz with water-damaged logic board; my replacement options are limited to the 17" 1.33 GHz or 17" 1.5 GHz for fit and function (after 2 years of "casual" looking, I found an affordable 1.33 GHz with a cracked screen. Buying a new 1.5 GHz logic board would bust my budget, so I can handle a slightly slower processor.) Hope this helps.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 828
