メインコンテンツにスキップ
The Toshiba Satellite L300 was a notebook designed and sold by Toshiba that came with a version of Windows Vista. They were sold around May-June 2009 and while ineligible for the free 7 upgrade, time past and upgrades are unclaimable now, run 7 home premium well without upgrades mainly because of Vista's resource hog quality. Also known as Toshiba Satellite L300-04P (PSLB8C-04P01X).
30回答 すべてを表示
締切られた回答
freezes when power supply plugged in.
I have the exact same problem on a Toshiba Satellite A205 PSAF3U-0P8015
Please let me know if you ever found a fix so that I can give it a try.
Toshiba Satellite A205 PSAF3U-0P8015 freezes when power supply plugged in.
By the way in my case I was able to format and reinstall windows from scratch since the battery is in very good shape and it gave me enough time to do the whole process. It has to be something on the voltage regulators or something like that, maybe even a Bios update, who knows? Anybody out there that knows? Maybe from Toshiba support. Is there is something like the capacitor pack mentioned above, can someone send me the diagram that shows which ones to replace? Any Help appreciated.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
@Philip de Jongh, here is a decent video that will show you what to do. Also, some good pictures on here Get the datasheet for the caps from here
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
最も参考になった回答
@Philip de Jongh
Google "NEC tokin".
Look at images & you'll see the original, large cap + the four, smaller ones that many people reported do a better job. Apparently, if you replace with the same NEC, it'll happen again.
Good luck
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 357
