メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
締切られた回答
Replaced Interconnect Cable On iPhone 5 Now Won't Turn On
My friend gave me two iPhone's (5) so I can replace the housing of one working iphone with the other one that's broken. I did it and gave him the working one. Then he tells me to fix the one that won't turn on, so another friend lent me his iphone so i could use his battery on the broken one to see if its the battery thats faulty and to my surprise it was. So I ordered a battery online and installed it but during the installation I broke one interconnect cable and took it out and closed it. I turned it on and it worked so i turned it off and ordered the cable. When the cable arrived, I opened the iphone connected it and closed it. Now it won't turn on and does nothing. I have tried everything, I did a hard reset, I plugged it into the wall and computer, I opened it and took it apart, put it back together again perfectly and it still does not turn on. I have one week before I need to give it back. HELP!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Does iTunes reconise it when plugged in?
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
No The Computer Doesnt Recognize It At All! ):
さんによる
Was the phone turned off when putting new cables on?
Did you pry the old cables off with a metal object?
さんによる
Nope I Turned The Phone Off Took Out The Display Correctly Disconnected The Battery Put The Interconnect Cable That Was Missing Connected The Display Connected the Battery Again Put The Metal Shield Over The Connections Closed It And It Wont Turn On
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 163
